HELP!! IT'S BACK code 33
Old Apr 12, 2001 | 04:20 PM
gt auto's Avatar
Ok it's back. I thought i had it. Awhile ago I started to get the code 33 After about $300 I thought I had it. New maf,maf power reley,burn off reley,and several other parts.
When it went away it also cooled off here in FL now it is starting to warm back up would this have anything to do with it?? What happens is I will be driving along then the car will start loosing power like it is running out of gas or something then that dreded check eng. light comes on. It will still run good as long as you don't try to get it up over 2000 rpm. Afte that it just starts cutting out you can punch it and it just wont get up the rpms it starts to dog out HELP!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 12, 2001 | 04:22 PM
gt auto's Avatar
oh yea it's a 88 with a 305 auto
Old Apr 12, 2001 | 07:51 PM
rondubbs's Avatar
are your connections clean? maybe the warm weather is causing moisture and condensation on the connections,,
Old Apr 13, 2001 | 07:29 PM
Guest
Guest
Posts: n/a
What mods to the car?
Whats the TPS set at? Its probably too high...
Old Apr 14, 2001 | 10:18 PM
chrisfrerick's Avatar
is that code maf burn off relay or sensor? i used to get the code for the burnoff lead on and off. it turns out that it would come on when there was an air leak before the sensor, after fixing that it didnt come back on.
Old Apr 15, 2001 | 06:47 PM
gt auto's Avatar
no mods all stock. it almost feels like it is running out of gas. as long as I don't get over 2000 rpms it's fine if i punch it it will bogg down. Would a 33 show if it was a fule prob??
Old Apr 15, 2001 | 07:09 PM
rondubbs's Avatar
if its not dirty connections, tps, or vacuum air leak somewhere in the hoses,, then id look at the maf again ,, you might of got a defective one.. is your new one a stock bosch or an aftermarket thick filmed maf??
Old Apr 16, 2001 | 10:24 PM
gt auto's Avatar
Is there any way to test the MAF??? Also it died today the fule pump went out would this kick the code 33 if it was getting bad??
lee01
Apr 9, 2016 01:56 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
