Help please! car DIED!
Was drivng home from the store, car died! Checked for spark, none! Changed teh coil, no change! Changed the ignition module......NOTHING! STUMPED AND PISSED! Please help
Transmission: 4L80E/4L80E
What engine/induction?
Probably a loose wire someplace, have you checked for power to the proper places?
Car: 4
Engine: 6
Transmission: 5
Have you tried a new rotor?
I still carry one around in my car; back in the Civil War days, I got a couple of dates by rescuing damsels in distress whose rotor had failed while driving down the road..... and I could make their car instantly start up and drive just like it did, like nothing ever happened, in about 30 seconds.
Battery is good. Been checking spark by putting a plug into the wire and grounding it on the intake.
HOW do you check the pick up ??? That was my next guess. GUESS!
I put a test light to the module and the wires going to the module. Now, I got power when I put the test light to the two prong wire that goes to the coil from the distributor, but no juice on any of the 4 prong's of the second plug. None on the module which is new. No juice to any of the two prongs that hook to the distributor? I'm thinking my pick up is fired? Never had to deal with this ever???????
Your help is greatly appricated!
OK, I changed the mag. pick up, STILL NOTHING! NO SPARK!!!! So my next question is;
WHen I put a test light to the ignition mod. Which termainals shoud light the light up? THere is one terminal that goes to the coil which has 2 prongs. then, there is the second prong which has 4 terminals. There is also two prongs which go to the magnetic pick up.
H E L P PLEASE:hail:
fuel psi is 43psi
changed mod.
changed coil
changed mag. pickup
fuel psi is 43psi
changed mod.
changed coil
changed mag. pickup
db057
Aug 11, 2015 10:11 PM
