Somebody says I can't use these tires.
When I was at Costco looking at the price of tires he said he wouldn't sell me P245/50R16 or anything similar because I have a base camaro.
He said something about the car not handling it or something.
I don't believe it... but... Does he know what he is talking about?
'86 Camaro
2.8 MPFI
AC Delco RapidFire SparkPlugs
Premium Gold Distributor Cap & Rotor
'86 Camaro
2.8 MPFI
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
no, he does not know what he is talking about. if you have the 16x8 wheels, those tires will fit fine. the 245/50's came on the z28 and the 235/55 came on the rs as far as i know. the tires are almost the same and the wheels for the z and the rs are the same.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
Dart equipped 406
12.20 @ 115.25 mph
88 S10
Dropped 3/4
Dart equipped 406
12.20 @ 115.25 mph
they(common auto stores) wont install tires of different size(like if you wanted 245s on the back, and 225's on the front) and i believe they wont install anything but factory sizes also.. its quite annoying, so if you ahve to, just get the tires there, and take them to a garage and say you want them put on.
- 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
- 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
<font face="Verdana, Arial" size="2">Originally posted by mtx28:
its quite annoying, so if you have to, just get the tires there, and take them to a garage and say you want them put on.
</font>
</font>
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Car: Death Mobile
Engine: 666 c.i.
I have never heard anything so ridiculous. Now, if you were trying to install those on 15" rims, I can see their point. But, if you have the proper 16" rims, they will work just fine.
I should add, that your speedo may not read correctly though. GM put different combinations of speedo gears in various F-bodies depending on the tires that were installed stock on the car. I just thought I should warn you about that part.
Car: 1986 Firebird
Engine: 2.8 V6
Tec-21, I still say you should've told him off.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 2006 Silverado 1500
Engine: 5.3L
not to sound like an *** or anything, but if someone refuses to sell you something, go somewhere else. kinda reminds me of someone claiming to not be able to insure an iroc because it was too fast. just go somewhere else if they are giving you a hassle.
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Just look at the moron telling you the BUll.S**T to shove his head up his giant intellect.
If he is stupid enough to hand you that kind of crap, I wouldn't want that fool working on my car!
<font face="Verdana, Arial" size="2">Originally posted by Tec21-CamaroLover:
Z28's came with the same steering and suspension system as RS' right?</font>
Just make certain you have wheels with the correct offset on both the front and rear. The front wheels and tires have very little room for extra travel with 16x8" wide wheels and 245/50 tires. It is very easy to get interference from the brake anchor bracket, steering arms on the spindles, and the ends of the stabilizer bars. You must have the offset correct on the front to clear everything. The rear axle is a lot more forgiving, but if you want an equal track on the front and rear you really need to install two different offset wheels on teh front and rear. Check the Tech Section for correct offsets.
If you showed them a set of wheels that would cause problems and asked to have the tires mounted on them, I could understand why they would have been wary. If that were the case, they could have at least explained why they thought the fit would be bad. It sounds more like they were just being too generic, and might not have known the differences that exist anyway.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
I should add, that your speedo may not read correctly though. GM put different combinations of speedo gears in various F-bodies depending on the tires that were installed stock on the car. I just thought I should warn you about that part.</font>
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
F##k that guy! I'm running 245/60 R15's on stock rims, and have no problems at all. In fact, I think it handles better that stock! Just get a set of BFG T/A's from tirerack.com or something in the size you want. Have someone mount them, then ****** up that knucklehead and take him for a spin!
Its an insurance issue. The car didnt come with those oem (your car is not an Iroc right?). Some places like sams costco ****-mart, wont put them on because they feel its a liability. They usually wont put a tire on that has less of a speed rating then the car came with also.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i agree with everyone. if got 16 inch rims on an 91 RS and i would tell ya not to buy anything less then 245 50 r 16 . thats what i run and they dont stick out at all
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler
Soon to come .SLP Posi 323,Spohn LCA's and panhard bar,Ascd ram air hood, Z28 spoiler and grille,white guage faces.
91 camaro RS
- 305 TBI
Car: Death Mobile
Engine: 666 c.i.
Keith, the stock 215/65/15s are slightly taller than the stock 245/50/16s. (About 1/2 taller). That is why when BOTH had 2.73s, both had a 17 tooth Drive Gear, but the 215/65/15s had a 37 tooth Driven Gear and the 245/50/16s had a 38 tooth Driven Gear.
225/60/15s are the same height as 245/50/16s, but 225/60/15s weren't stock.
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
GO ELSEwhere, WERE the speed ratings the same ,, ie V rated Z rated,, high perf cars in AUSTRALIA where i live use V or Z rated tires,,, they wont put el cheapo,wide tires on a H,PERF car,, here you got insurance problems,if you flatten some one due to a tire failing ,,,,go elseware mate ,,,,the new bridgestones are good, or dunlop from europe,, good stuff,,, aint bought B.F.goodrich in about 20yrs ,,can,t comment
