Radiator leak, can it be fixed or has to be replaced
Old Apr 18, 2001 | 10:40 PM
green_is's Avatar
The car has a radiator leak. is there any way i can fix it without having to replace the whole thing
Old Apr 18, 2001 | 10:46 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Depends on how big and where the leak is.
If its a small leak you might be able to get away with a stop leak thrown in, but I don't like using that stuff.
If its like most thirdgens, the plastic tank is split, and that means a new radiator is in your future.
It would cost just as much to put a new tank on as it would to replace it.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Apr 19, 2001 | 04:15 AM
ede's Avatar
ede
i've fixed a lot of radiator leaks. find the leak, clean it up and solder it. i use air and windex to soap with. stuff a few rags in the openings and stick a air gun in with about 15 PSI.use 50/50 solid core solder w/flux.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 19, 2001 | 08:02 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
I guess the question of the days is ...is what kind or car??
Ede is right, if its a metal tank.
If its a thirdgen, aren't most the tanks plastic??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Apr 19, 2001 | 08:03 AM
Steve89GTA's Avatar
The aluminum Rads are crap....they're light but weak. I swapped mine with a 3 core steel one and had no problems for 3 years now.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Apr 19, 2001 | 08:13 AM
smithtc's Avatar
I would go with what ede said...or you might can jb weld it!
Old Apr 19, 2001 | 12:26 PM
85berlinetta's Avatar
Auto Zone has an aluminium 3 core radiator for $136.00. It also has a life time waranty on it.
lg4
slp muffler
pro flow air cleaner
performer intake
cat delete
ratchet shifter
160* stat
q-jet from 1970 vette
Old Apr 19, 2001 | 11:39 PM
BigChevy342's Avatar
Autozone has a lifetime warranty on everything, even there clutches, its all crap, dont go with autozone, Sure you will have a lifetime warranty but you will be replacing the radiator every six months.
jklein337
Sep 19, 2018 06:23 PM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
mizz0313
Aug 12, 2015 06:45 AM
