Bored.030, 400 Crank, 6" Rods...Cubes???
Old Jul 23, 2004 | 09:57 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
my shortblock is a standard 350 block bored .030 with a 400 crank and 6" rods instead of the 5.7's. what will my exact cubes be? i know id be running about 388 with 5.7's but what about with 6's?
Old Jul 23, 2004 | 09:59 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
383 CID, rods play no part at all in engine displacement.
Old Jul 23, 2004 | 10:12 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
oops, i guess thats common knowledge.....well sorry for the dumb question but wouldnt the over bore give a few extra cubes?? and the longer rods should provide more torque correct?
Old Jul 23, 2004 | 11:03 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yes the .03" over bore gives you 383 CID instead of 377 with a standard 4.0" bore. The effects of a longer rod are arguable at best, it doesn't really do anything other then reduce rod angularity and bore wear.
Old Jul 23, 2004 | 11:11 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
:hail: :hail: :hail: you are awesome. btw i saw your sig what kind of power do you expect to see from the new engine?
Old Jul 23, 2004 | 11:46 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I'm hoping for a true 400hp at the crank. DD2000 says 480hp.
Old Jul 24, 2004 | 12:47 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Gotta love the Desktop Dyno predictions. Maybe thats how the r!cers get so much horsepower.
Another thing rod length does is create more clearance between the piston skirt and the crankshaft counterweights.
Old Jul 24, 2004 | 01:39 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well "my" desktop dyno with afr 190's and a crane 284/292 cam gave me 541 hp and 507 tq flywheel...........well see if i actually get there
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
