PCV question....
Old Jul 23, 2004 | 11:54 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
PCV question....
Where it goes into the valve cover on the passenger side is kind of loose, not very tight. Do you think I need a new one? Or do I need a new rubber piece thats on the valve cover where it goes into? (Are these even available?)
Thanks!
Old Jul 23, 2004 | 11:56 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes you should get a new VC grommet, you can get them at any autoparts place. You might as well get a new PCV too while your at it, they are very cheap.
Old Jul 24, 2004 | 12:41 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
yup, i second the VC grommet replacement idea, they are at most autoparts stores for cheap, either in the shiney-but-doesn't-go-too-fast-though section or in the Help! section.
Old Jul 24, 2004 | 12:56 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks guys! Does the old one just peel off?
Old Jul 24, 2004 | 01:00 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Its a grommet. It will pop out. Think of an hourglass design. Just really really REALLY squished....and made of rubber, not sand.
I take a sharp screwdriver and jam it into the inner side of it and lever it out. Takes a little massaging, but it will pop out.
Old Jul 24, 2004 | 01:12 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Its probably old and brittle now. It will probably just crack in half, and you can pullout the pieces. Make sure nothing falls in, or you will have to try and vacuum it out with a shop vac.
Old Jul 24, 2004 | 01:16 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Eh, that's a good point. Remove the valve cover first, put it on the ground, then purposly break it.
Old Jul 24, 2004 | 02:15 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
passenger side? I think the PCV is on the driver side valve cover. There is something on the passenger side valve cover (with TPI) that looks very similar to a PCV valve when you look at it, but when you pull it, you'll notice its hollow and runs to the TPI throttle body. Can't think of the damn name of that thing.
Anyway.....It had been so long since I changed by PCV I almost put it in the passenger side by mistake. OOops.
Old Jul 24, 2004 | 03:00 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Its a 90 deg elbow that takes a small hose from the rear passenger side valve cover to the TPI. Available at the dealer for a couple of bucks. Its not the groment for the PCV valve thats pictured but it may reguire one.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
