Stroking 350 with .040" pistons???
Old Jul 26, 2004 | 04:54 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Do i have any options of stroking my motor that was rebuilt with a .o40" overbore? Or should I just go get a rebuildable block from a junk yard?
Old Jul 26, 2004 | 05:43 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Stroke it and go 60 over
Old Jul 26, 2004 | 05:57 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You might beable to over bore it 0.06 over if you have it sonic checked. But you might as well start with a virgin block if you can find one.
Old Jul 26, 2004 | 05:59 PM
IROC_385Z's Avatar
Car: 88 Camaro IROC-Z
Engine: SBC 385
Transmission: 700 w/ manual valvebody & 2400 TCI
Axle/Gears: 9-bolt B&W w/ 3.70s
DO NOT go 60 over unless you have an oldskool block from the 60s/early 70s. 40 over is the most for a newer factory block. Stroke should have no real impact on how far you can bore the block...just don't use the short rods from a 400 if you stroke it. I have a 385, 4.04 x 3.75 and its fine. Use 5.7 or longer rods and don't worry about it.
Old Jul 26, 2004 | 06:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
why is it 30, 40 , 60? why not 50?
Old Jul 26, 2004 | 06:05 PM
kevinc's Avatar
Car: 1982 Z28
Call around and get quotes for 0.050" oversize pistons and you'll find out.
Old Jul 26, 2004 | 06:07 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I understand 50 is custom but why don they mass produce them. People would rather go 50 over then 60..
Old Jul 26, 2004 | 06:35 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Because usually a .03 is required to cleanup the bore and then on the next overbore another .03 over is .06. But sometimes a .04 overbore is required to cleanup a damaged bore.
Old Jul 26, 2004 | 09:12 PM
Car: 89 camaro RS
My problem is trying to find .040" over pistons that work in a stroker application. All I can find is .030".
Old Jul 26, 2004 | 10:23 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
There are plenty, you can't just look in a catalog though because they only list the most popular size. You have to look in the piston manufactors you want catalog to find them.
angel2794
Sep 8, 2015 06:22 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
Strick1
Sep 4, 2015 07:11 AM
85Special
Sep 3, 2015 04:21 PM
Formula_88AE
Sep 3, 2015 01:47 PM
