Keep Camaro Cool In summer??
Old Apr 21, 2001 | 11:40 PM
CAMARO82's Avatar
HOW DOES EVERYONE KEEP THERE CAMARO COOL IN THE SUMMER? I live in EL PASO TEXAS and Its Hott here in the summer but my car is already getting hott
Old Apr 22, 2001 | 12:39 AM
Enkil's Avatar
There's a number of things you could do...
A complete flushing of the coolant system wouldn't hurt..
A new thermostat and radiator cap wouldn't either, and they're not expensive at all.
You could make the fans come on at a lower temperature, either by buying a new chip or by turning the AC on.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Apr 22, 2001 | 12:46 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Pop in a 160 thermostat and get you an adjustable fan switch! There are some expensive adjustable fan switch kits out there! If you have an autozone there you can get one for $20 there! That's where I got mine and I've had it hooked up for over 2 years with no probs!! The ECM needs to see 173 degrees to work properly! With my setup, my car runs right about 175 all the time!! You'll have to "test and tune" to get it set right!! Then, in the winter you can put a 180 back in so your heater will work properly and you can adjust the fan switch back up for the 180!! That's what I do here in MO! (Sometimes I leave the 160 in through winter too tho)
Old Apr 22, 2001 | 12:47 AM
Vader's Avatar
82,
Enkil covered it pretty well. There are only a couple of other odd things to check.
1. Make sure the radiator and AC condenser are clean on the OUTSIDE as well. The space between the two is often a good place to find a collection of grass, leaves, seeds, paper, road debris (that Honda you blew away and then disappeared from view - it's pro'lly in there too), etc.
2. Make sure the air deflectors installed on the lower radiator support are in place and not broken. These are important to direct air through the radiator instead of around it.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Jul 4, 2002 | 09:25 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
El Paso may be small as compared to some metro's .. but we've got an auto zone
Old Jul 4, 2002 | 09:48 PM
iroc22's Avatar
Redline's water wetter seems to work quite well.
Old Jul 4, 2002 | 09:51 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
It gets just a little hot here in phx too. Got up to 116 last week and I think it was 109 today.
I do the cooling system flush and the cleaning out the radiator.
I still have the factory thermostat in and have not had a problem. The car actually runs cooler if the a/c is on.
This may sound strange to some people, but I am a firm believer that a clean engine is a cooler engine. Once a month with simple green and a power washer does a fine job.
Old Jul 4, 2002 | 11:41 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
160 degrees thermo
I swear by the 160 degree thermo stat. And I leave it in the winter. Never had a problem with my heater.
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
TheExaminer
Aug 19, 2015 10:07 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
