Fuel Filter?
Old Aug 2, 2004 | 02:53 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Fuel Filter?
Where is the fuel filter located on these F-Body's. I checked all over under teh hood and I can't find it. Is it underneath the car?
Old Aug 2, 2004 | 03:26 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Fuel Filter?
It should be located under the car on the drivers side between the wheels.
Old Aug 2, 2004 | 03:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is under the car just insdie the fram rail. It is right under where the driver seat is located. It is a silver cylindrical can.
Old Aug 2, 2004 | 04:14 PM
ThraxXx's Avatar
Ok..gonna change that out. Only thing I didn't due durring the tuneup cuz we couldn't find it hehe. Thanks for the help.
Old Aug 2, 2004 | 04:18 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
A little word of wisdom here if you have never done this before. Remove the gas cap first and leave it off until done and use two wrenches when removing and installing the filter or you will make pretzels out of those fuel lines. Just a thought there!!!!!!!!!!!!
Old Aug 2, 2004 | 04:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Remove the gas cap? Why?
Old Aug 2, 2004 | 04:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
To relieve any pressure that has built up in the tank unless you like sprayers.
Old Aug 2, 2004 | 04:30 PM
Exactly right Trickster. I always take off my cap whenever I work with the fuel system. I've done it without only "once" and I dont like watching fuel shoot out under pressure. Makes a flammable mess!
Old Aug 2, 2004 | 04:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, but why leave it off?
Old Aug 2, 2004 | 04:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
For me and probably many others it is a force of habit. By leaving the gas cap off it gives the gas fumes another avenue of escape along with any more pressure that might build up in the tank while you are working especially if it is in hot weather.
Old Aug 2, 2004 | 05:34 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will really want to relieve the pressure if you don't want to wear an arm load of gas. You should also, dissable the fuel pump and run the car until it iss out of gas. That makes for an even better install/removal. I am always too lazy and just change it with unpressureinzed fuel in the line and let it catch in a coffee can. Make sure you use two wrenches like Trickster said.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
