Why is my car making this sound?!?!
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
I finally got it running after a year now, and it ran good for a couple of days. Now it has this ticking sound, a rather loud one, you can here it when your driving. And it gets faster as the rpms go up. Also, when i rev the motor up, and when im giving it some gas on the road, it makes this weird popping sound also more frequent with the rpms, almost like a backfire but not. Can anyone tell me what is making these sounds???
Engine: 350 carb
Yea, I am gonna take the valve cover off and see whats up...and the rocker could be the thing that is making both of these sounds??
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by RB83L69
Sounds a bit like an exhaust rocker might have come off.
lol
remember the post you made awhile back, pointing out how when you tighten a poly lock the way they say in the instructions, it pulls it up higher.....(more lash)
but if you tighten them, then turn them both, they dont move?
well i did my whole engine your way, but because im a curious guy, i did one the "normal" way. the exhaust valve for #8.. (in retrospect, i should have picked a easier one to get at...)
sure enough, after 700miles, i had to retighten that one.
only that one.
everything else checked out fine... one of the others was slightly looser then what i set it to, but a nudge of the wrench made it perfect... it was bearly off. i could have left it alone.
so as of right now, i have almost 1k on the valve lash set the way you posted... works great.
post just reminded me of it, since the #8 exhaust was ticking and "popping" from the loose rocker.
Engine: 350 carb
Well i pulled off both valve covers and sure enough, the number 1 exhaust valve was so loose, i could spin it 360 degrees around, that is crazy!....there were others that were a little loose so i need to get them, my friend is coming over to do it for me. Will this solve my problems? I took off the air cleaner and the big popping sound was coming from inside the carb, down in the engine when i revved it up. I hope its just the rockers and nothing else
Also, what is he talking about poly locks, should i get them? and what makes the rockers get so loose???
Car: 91 Camaro Vert
what made it that loose? i can only give you my theory.
it was probly loose and not set right orignally. when you run the engine with them loose, they can spin... so it just vibrated looser and looser.
Engine: 350 carb
you are exactly right, i know it wasnt set, and still ran the engine. Thanks for all you guys help, and i will get back to you when i set them......this will fix both bad sounds right? ticking and popping?
Car: 91 Camaro Vert
because the valve isnt opening enough, you build pressure in that cyl that doesnt get released.
the popping you hear in the intake is some of that coming out the intake port when the intake valve opens.
Linson
Aug 21, 2015 02:12 PM
