Head Gasket
Old Apr 25, 2001 | 01:11 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Head Gasket
I am getting ready to put my heads on the block. The heads have been milled and the block was decked and cleaned. The gasket is a Fel-Pro steel shim gasket. Do I need to use any sealant in the water pasages or just torque it down dry.
Brian Felts
Old Apr 25, 2001 | 01:24 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I would spray it with some gasket spray. Not only will it help the gasket seal but it will also hold the gasket in place when your putting everything down.
Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job.
Old Apr 25, 2001 | 06:53 PM
ede's Avatar
ede
i wouldn't use a uncoated shim type gasket. fel pro makes a coated shim gasket. like you were told use a spray sealer. i like k&w copper in a spray can.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
