Lt1 Cam????
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
Lt1 Cam????
Well i bought my lt1 cam of ebay, and it does not have the long pin like my buddys lt1 cam. It came of a 1994 350 lt1. Is there any other way of nowing what an lt1 cam is based on the little #s it has?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The 93 and 94 LT1 cams had a shorter dowel pin because of the non vented Opti. I would just measure the specs of it to varify.
Car: '90 RS
Engine: 377 LSX
Any of the LT1 cams will work. You only have to modify the later ones by griding off a part of the dowel pin. The dowel pin on your stock cam is smaller than the ones found on the LT1 cams. You may not have to cut it down if it clears the timing cover. The 95 thru 97 LT1 cams must be cut.
Car: '90 RS
Engine: 377 LSX
Originally posted by 90tbi305
so it is the right cam?
Engine: 5.7 tbi
Transmission: t5
Whats a b body on the chart above? By the pin there are only these #s (3...241.cpc.bc.) . is that the part # ?if not were is the part #?
Car: '90 RS
Engine: 377 LSX
Engine: 5.7 tbi
Transmission: t5
The only other thing that i can see is there is a ( 9 on the last big peace of metal , and in front of the second big peace of metal there is an A) Thats the only other #s that i see. Any thing you could remember?
Car: '90 RS
Engine: 377 LSX
What do i measure? There is so many things to measure.
This should help you
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
There's a lot to explain, when it comes to degreeing or checking the #s of a cam.
There are a lot of guys here who could tell you how to do it but it's too time consuming.
Go to some of the cam companies sites like Crane or Comp and there will be a tech info section there that explains how to degree or check the specs of your cam.
There are some special tools that come in handy, like a dial indicator and a degree wheel.
At the very least youll need the degree wheel. And if you're serious about engine building, a dial indicator will be something that you'll find countless uses for, other than just degreeing cams.
It might seem like a big expense at first, but if you're comitted to learning engine building you'll be glad you spent the money.
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
mhhh, what kind of *-car is a caprice.
I've got one out of a 95, ready to install with a few other funny things...
is this good or bad?
greetings
S!MON
greetings
S!MON
Car: '90 RS
Engine: 377 LSX
Make sure it is not an LO3 or LO5 cam. Both of those motors were also found in that car. You could have also got the baby LT1 cam as well.
Car: '87 Camaro Z28
a lo3 in a 95 car, damn!
the problem is..the parts are at my aunts house in the US, so I can't check that ;(
all the parts will come in one big package, so I maybe should look into another cam?!
greetings
S!MON
p.s: I will open a new thread, cause it seems, that that is not the cam I want!
greetings
S!MON
Car: '90 RS
Engine: 377 LSX
New2Chevy
Sep 28, 2015 12:35 AM
