383 Stroker oil pan choices?
Old Aug 10, 2004 | 12:54 PM
AC's Avatar
AC
Car: Used to drive a camaro
I'm getting ready to seal up the bottom end of my 383 stroker. I wanted to know what oil pans you guys are using for your stroker engines. I'm using the Eagle ESP kit with Hbeam 5.7 rods. I also wanted to use a windage tray if possible.
Old Aug 10, 2004 | 01:24 PM
92Z's Avatar
92Z
I used the stock pan. Just snugged it up and rotated the engine by hand. I could feel one rod hitting. Removed the pan, looked for the scuff mark, and just "tweaked" it with a hammer. Needed only slight amount of clearancing. BTW i have Eagle 6 inch H-beam rods. HTH.
Old Aug 10, 2004 | 04:55 PM
daddy33's Avatar
Car: '85 Camaro
how about this Moroso oil pan? The part # is MOR-20180 and says that its made for 82-92 camaros. Will this one clear? I hope so because i got it for free and going to put it on my 383
Here is the link:
http://store.summitracing.com/partde...OR-20180&N=120 4294925232 4294925173 301046
Old Aug 11, 2004 | 07:16 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I'm using the Mororso 6qt pan MOR-20180, fits fine on my car.
Old Aug 11, 2004 | 08:18 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I have that moroso pan, and it hits a little on the steering gear.
Old Aug 11, 2004 | 12:00 PM
94zsson's Avatar
Car: 87 Z28
Engine: LT1 Hotcam motor
the canton pan works great as well and it comes with a built in windage and trap door for the oil pickup
Old Aug 11, 2004 | 12:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What block?
1-piece rear main seal or 2-piece? pass side dipstick or driver's side?
Nobody can pick a pan that will work without knowing those things.
Old Aug 11, 2004 | 01:00 PM
daddy33's Avatar
Car: '85 Camaro
i would get that canton oil pan but its like twice the price of the Moroso oil pan. My block is a 2-piece and has the driver side Dipstick
Old Aug 11, 2004 | 02:00 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
I just used the stock pan punched out a bit where it needed clearnance.
Old Aug 11, 2004 | 03:21 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I've also got the Moroso 6qt pan as well....it's a good pan especially for the price.
Old Aug 11, 2004 | 07:16 PM
BOTTLEDZ28's Avatar
Transmission: A4
i used the stock pan and used a hammer to bang out the spots where the rods hit. I did not use any windage tray. I orginally cut out a couple holes in the stock one but I could nto find any ARP bolts thatheld the oil pump AND windage tray on. I guess GM used a stud for this and then put a second nut on the stud after the tray was installed. I didnt want to reuse those 3 old studs and use ARP bolts for the rest so I just did with out the tray. I hope I dont kick myself for making that decision
Old Sep 24, 2004 | 12:46 PM
JesasaurusRex's Avatar
Says max stroke for that moroso (MOR-20180) is a 350 crank, does it clear a 400 crank or not? I have a 350 right now but I really wouldnt wanna buy another oil pan if i decide to throw a 383 in there.
Old Sep 24, 2004 | 12:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Says max stroke .... is a 350 crank, does it clear a 400 crank or not
Whaddya think? If it would fit a 400 stroke, would they have said that the max stroke it will fit is the 350? Or do you suppose, maybe they would have said something else?
I sure wouldn't buy it and expect it to work in that combo, given what they say. Sounds like they have some BTDT so I'd listen to them. But that's just me.
Old Sep 24, 2004 | 01:28 PM
jbenge has a 383 and is using that pan im just trying 2 find out if anybody else is so stop being such a jack ***
Old Sep 24, 2004 | 01:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Who, me? Jackass? I just quoted you, that's all. Sorry if it hurt. Sometimes the mirror is a bit harsh when somebody else holds it in front of one.
It's also possible that with "minor modifications" (read: beat it with a BFH) that it could be made to fit. It's also possible that what rods you use may impact that, just like it does block clearancing and cam selection. In other words, it's about guaranteed not to fit a stock 400 setup (stock rods), but when used with parts other than that, how could they or anybody else possibly answer that question?
Old Sep 24, 2004 | 03:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats a little harsh... we're only trying to help here.
I'd do what most people do... use the stock pan. If it does hit, pull out your BFH and make room. Its not hard if you take your time and be careful. Its ALOT cheaper and quicker than buying a new pan and waiting for it to get to you anyway.
Old Sep 24, 2004 | 03:56 PM
GRRRRRRRRRRRRRRRRRRRRRRR
Hotrodboba400
Dec 10, 2019 07:07 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
