Speedometer
Old Apr 27, 2001 | 03:05 PM
BenIroc's Avatar
Speedometer
My speedometer does not work, it just happened,no movement to any mile per hour nothing . I´ve looked at the connexion with
the trans and the kabel is OK in it.
Any ideas about what to look for, is there
any fuse, specific to the speedometer?
BenIroc
89 Iroc, 700 r4, 350 engine.
Old Apr 27, 2001 | 03:11 PM
Steve89GTA's Avatar
You have to move first....lol, just kidding.
The sender on your tranny is probably shot, although I've never heard of them going.
[This message has been edited by Steve89GTA (edited April 27, 2001).]
Old Apr 27, 2001 | 03:19 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
'89 did not have electic speedos on Camaros, only after '90 (Firebirds started in '87). Chances are your cable snapped, just unplug the connector behind the speedo and replace.
George P. Lara
1984 357 T5
1994 LT1 M6
SCCA, SCFB, SC3GFB
Old Apr 27, 2001 | 05:05 PM
BenIroc's Avatar
It is good if there is not electric speedo
in my car. I´ll look at the cable, I´ve heard
there is a sort of connection at the Cruise
Control transducer.........
Old Apr 28, 2001 | 07:19 AM
BenIroc's Avatar
Today i`ve got code 24. Why do I get a code
if the speedo is not electric?
Anybody has any idea if it can be anything
but the cable?
Old Apr 28, 2001 | 03:08 PM
MRZ28HO's Avatar
Engine: was: L69
All 3rd gens have speed sensors, regardless of eletric or cable speedos. The VSS the guys with ES refer to is supposedly on the trans, but on CS it is behind the speedo guage (should be either blue or yellow square driven with the cable). Check to see that the speedo is properly hooked up to the guage, this will set off the code if not hooked up. If your VSS fail it could also trip the code, but the needle should still indicate the correct speed. If you have cruise control, check all the cable connections. Although one of my '84s doesn't have the old style transducer system (two cruise controls were offered, I have one with the transducer and one that is totally eletrical), your's might and you need to verify this.
Old Apr 28, 2001 | 04:05 PM
86Chicken's Avatar
BTW: 'Birds got electric speedos in 86.
Dale
The Bird
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
