Headers keep burning plug wires...
Old Apr 29, 2001 | 11:12 AM
RoadRocket L98's Avatar
Well my headers keep burning my spark plug wires. I never though the car could run any worse but last night I experienced running on about 6 cylinders, maybe 5 I dont know. Anyway, Ive tried different routing but no matter where I put them, they go bad. This is really starting to get to me. Anyone have ideas? Thanks. BTW, the way my Formula was could smoke the post-header car I have now. Pretty sad huh?
'83 Firebird 2.8
'89 Firebird Formula 350
Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
No real ET yet...
Old Apr 29, 2001 | 11:16 AM
ede's Avatar
ede
i have nomax sheathing on mine, no worrys. accel makes the rubber looking insulation for wires too, never used it but hear it works good too.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 29, 2001 | 01:09 PM
speedlvr's Avatar
I've seen posts where guys talk about how their Accel wires cracked or burned from the heat. I have Taylor with a lifetime warranty. When I bought them I was told if they melted or burned, I could get my money back. So far, so good. A few of the boots are 1" away from the headers.
[This message has been edited by speedlvr (edited April 29, 2001).]
Old Apr 29, 2001 | 01:42 PM
Slow83Z28Camaro's Avatar
get accel 8.8 plug wires, they are awsome
Old Apr 29, 2001 | 03:12 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I tried the heat-proof fiberglass wire shields that are sold in Jegs and Summit, but they are only good up to a point. If the heat shield is in direct contact with the header, it will burn. Trust me, I've burned through a couple of them. The only real solution is to figure out a way to secure the wires with ties, clamps, or whatever so it can't contact the header tubes. I finally had to clamp my plug wires to the AIR tubes above my exhaust pipes. The AIR tubes don't get nearly as hot as the exhaust pipe itself, and this allowed me to position them precisely enough so that they never come in direct contact with the exhaust tubes.
I also got the Accel 300+ wires, because they have the highest temperature rating of any other aftermarket plug wire I looked at. Extra thick silicone layers, and an additional silicone jacket over the last 12" if wire closest to the heads. They are so big that no wire looms will ever contain them, but they have never burned out on me since I installed them over two years ago.
I cooked several sets of Taylor wires, and numerous Jacobs wire sets before hitting on the solution above. Lifetime warranty on wires is ok, but if you have to mail your barbecued wires to them before they will send you new ones, that typically means that your car will be down for a week every time they have to do this for you.
89 IROC with lots o' stuff
-=ICON Motorsports=-
Old Apr 29, 2001 | 05:21 PM
speedlvr's Avatar
I can take them back to the parts store where I bought them. No mailing involved and no barbeque yet.
Old Apr 29, 2001 | 07:50 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get a set of wire looms.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Apr 29, 2001 | 08:03 PM
Jimmy_CFH's Avatar
Accell sells good wire looms. I have a set on my 77 1/2-ton p/u, and they work well with the 8.8 wires. I'm not sure what kind of set-ups they have for centerbolt valve covers though. Call Jeg's and ask them what they have. Accell has about the best ignition products out there, I've used a couple different sets of wires. I was real dissapointed with the Holley and MSD wires.
84CAMAROHIGHOUTPUT's Avatar
accel makes smaller length plugs if that help your scenario any.
Old Apr 30, 2001 | 12:45 AM
86TransAmTPI's Avatar
I have accel 300+ 8.8 wires and theyre greaaaaaaaaat.I went through a couple stock sets but these wires gave me no problems at all.
Check out My Trans Am:
http://hometown.aol.com/italianknight178/index.html
Old Apr 30, 2001 | 01:57 AM
jaretz28's Avatar
Me too. Set of Accel 8.8 with some nice moroso wire looms. Never had a problem, never will.
Old Apr 30, 2001 | 02:07 AM
burnoutrpm's Avatar
are they all 90 degree boots??? if not try getting the wires with the all 90 degree boots
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
tricky1
Aug 23, 2015 01:17 PM
Exxon Limited
Aug 9, 2015 08:13 PM
