Help! Motor running rich!
Old Aug 20, 2004 | 05:25 PM
1badmopar's Avatar
Car: 1966 Plymouth
Engine: 520" RB
Transmission: 727 Torqueflite
I converted a TPI L98 to a Ramjet intake set-up, and placed it in an S-10. The problem is that the motor seems to run rich no matter what I do. I am down to 19 lb injectors and datamaster still shows 1.5ms pulse widths. The LTerm and STerm both show to be way rich and the motor is puffing smoke when I first nail the gas.
To convert the intakes, I had to convert to a newer MAP sensor that mounts on the RamJet intake. I also had to get rid of the EGR.
Do you think either of these could be causing the motor to run rich? What other things should I look for?
How can I lean it out, without burning a prom?
Thanks.
MustangBeater20
Oct 29, 2022 09:20 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Elliswon
Aug 10, 2015 12:33 PM
squiggy2
Aug 9, 2015 09:30 PM
