Head ID
Old Aug 21, 2004 | 01:29 PM
BC85Z28's Avatar
Car: 85 Z28
Engine: 5.7 liter 350 TPI
Head ID
Can anyone tell me by the markings on these heads what they are?
Old Aug 21, 2004 | 01:33 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
tell us the markings and maybe we can help
sadly not everyone on the boards is a mind reader, we need the info typed
Old Aug 21, 2004 | 01:35 PM
BC85Z28's Avatar
Car: 85 Z28
We are trying to get a picture put on here
Old Aug 21, 2004 | 01:41 PM
BC85Z28's Avatar
Car: 85 Z28
This should work
Old Aug 21, 2004 | 01:43 PM
BC85Z28's Avatar
Car: 85 Z28
okay do you know how to open the attachment? Or can you just tell me how to put a picture on here.
Old Aug 21, 2004 | 02:04 PM
BC85Z28's Avatar
Car: 85 Z28
Heads IDHere is the pic
Here is the pic hopefully.
Old Aug 21, 2004 | 02:19 PM
BC85Z28's Avatar
Car: 85 Z28
Heads ID
I hope this will work!
Old Aug 21, 2004 | 03:20 PM
ljnowell's Avatar
wow, still no pictures. You shuold just give us the numbers off the head.
Old Aug 24, 2004 | 12:59 AM
BC85Z28's Avatar
Car: 85 Z28
If anyone ever looks at this post we found a head identification chart and it seems to be the 70 LT1 heads
Old Aug 24, 2004 | 08:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
So, besides just jumping to the conclusion that they're a highly desirable set of heads, what's the casting number?
Pictures must be about 100k file size, or smaller. To post one, you click on the little "Browse" button at the bottom of the page; that will give you a "File Open" looking dialog box; pick th pic you want to post; and click OK. If your pic is larger than 100k, then you need to use some sort of image editing software such as Photoshop ($$$$$$$$) or Paint Shop Pro to either crop out the parts of the pic that don't matter, or reduce the resolution, or increase the data compression (which also reduces the quality, but if done correctly you can avoid damging it so bad tha tthe point of the pic is lost). It's usually impossible to just download a pic out of your camera and post it as it is.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
