Car is deiseling!!!
Old Aug 22, 2004 | 09:35 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
Car is deiseling!!!
How do you fix this....
I have a carbed 355 and when i shut the car off in park, it tries to restart itself and then throws the belt off track. But when I shut the car off in drive with a load still on the motor then it's fine....what causes this and how can i fix it.
Thanks,
25thredrs
Old Aug 22, 2004 | 09:36 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Too much timing is a common cause.
Old Aug 22, 2004 | 10:07 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How many miles on the engine and does it do this if you shut down in drive then shift to park after the engine is off?
Old Aug 22, 2004 | 10:11 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
The engine only has about 200 miles on it. And no, it doesnt try to restart after putting it in park....If you shut it off in drive, it is then safe to put it in park. also it will run fine and idle in park, you just cant turn it off in park.
thanks
Old Aug 22, 2004 | 10:21 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Try lowering the idle speed.
Old Aug 22, 2004 | 10:55 PM
25thRedRS's Avatar
Car: 1992 Camaro RS
I've tried lowering and raising the idle..right now it's idleing at right around 1000rpm in park.
Old Aug 22, 2004 | 11:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
lower it more, it should be around 750 in park
Old Aug 22, 2004 | 11:42 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
What is it in drive? Try lowering it some more. I think you are dieseling because you have too much idle speed.
Old Aug 22, 2004 | 11:49 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I'm with IHI on this one... What is your base timing set at? Are you running your vacuum advance off ported or manifold vacuum??
Old Aug 23, 2004 | 09:14 AM
25thRedRS's Avatar
Car: 1992 Camaro RS
My idle drops to 500 when i put it in drive....any lower and it will stall..i think it's because of my cam...it's a .510 lift......the timing right now is set at 18 degress BTDC...i'm running an MSD Distributer and a MSD Blaster 2 coil...the distributor is vacume advance and runs to a port in the side of the carb.
Old Aug 23, 2004 | 11:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The cam lift doesn't matter.
Sounds like you have carb/dist tuning issues, that are requiring the idle to be set too high (throttle blades too far open).
You need to get the carb straightened out to where it will idle at 800 or so out of gear, and 600 or so in gear. That will fix the run-on problem.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
