Can wrong valve springs have a major effect in HP???
Old Aug 25, 2004 | 08:46 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Well I have edelbrock aluminum RPM heads with a Comp cam flat tappet XE274 cam and compcams 1.6 magnum roller tip rockers. I was wondering if the valve springs could be holding the engine back? Maybe upgrading to some comp 986 springs would help? What do you guys think?
Old Aug 25, 2004 | 08:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you had coil bind and bent all the pushrods, that would have a major effect in HP, or if your springs were too week and you had early valve float.
Old Aug 25, 2004 | 09:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Or, if they are too stiff, they effect the action of the lifters hydraulic mechanism, ultimatly, risking collapsation. But that has to be really stiff.
What are the spring specs you have now?
Old Aug 25, 2004 | 09:51 PM
Car: 89 camaro RS
thats the problem I cant really find specs on the springs that come with the edelbrock heads. all I know is that there is a max lift of .575",1.45 spring diameter thats it.
Old Aug 25, 2004 | 10:05 PM
Car: 89 camaro RS
nvm I found some specs
Valve spring Dia. 1.45"
Valve spring installed height 1.800"
Valve spring seat pressure 120#
valve spring seat pressure at .500" lift 320#
Old Aug 25, 2004 | 10:18 PM
Car: 89 camaro RS
ok here are the specs of the 986 springs.
Max valve lift...560"
spring O.D. 1.430" double spring
seat pressure: 132#@ 1.750" seat, 280# @ 1.250" open
coil bind @ 1.150"
Rate 296#/inch
deracer
Apr 11, 2016 12:04 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
