Weird Slapping Noise at idle...
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Hey guys,
I have this weird slapping kind of knock noise when my car is idling. It is especially noticable at start up. It sounds like it is coming from the driver's side part of the engine somewhere. I thought, and still do think, it might be an exhaust leak at the y-pipe to manifold flange because I had my exhaust guy try putting an aftermarket y-pipe on to no avail, so he put back on the stocker. The noise is like a slap, slap, slap, or puff, puff, puff...my dad said it sounded like a slapping piston, but its not extremely loud, only at idle is it really noticable. I know its not the injector or valve tick, its totally different. Help!
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
when you rev it up does the noise go away or get louder and advance with the engines revs ??
its possible especially since you had your exhaust worked on already that its leaking now because he took it apart
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
detonation is a pinging.
Is "ticking" a good description of this noise? if so, then yes an exhaust leak is a definite possibity.
Car: 1992 Camaro RS
Engine: 305 L03
Its not a "ticking" so to say, its more of a puff, puff, puff, slap, slap, slap type of noise. My timing is fine, I set it to 0* spec and then advanced it to 2* where it was running nicely. Yes, I disconnected the ESC to set base timing. I'm hoping its exhaust, but what else do you think?
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
it sounds like exhaust, but at the same time, you say it is only noticeable at idle...but that could also be because you have loud exhaust...i would say exhaust...try tightening the connection...
Josh
Josh
If it's exhaust it will be in tune with RPM and it will GET LOUDER THE MORE LOAD YOU PUT ON THE ENGINE. If it's constant in volume or goes away when you get above idle speeds it's not an exhaust leak.
A valve tap will be very similar but it'll be constant volume regardless of engine load.
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
maybe you collapsed a piston. sounds alot like piston slap. What type of pistons are you running? do you know what your piston to wall clearances?
IF you want to hear some good piston slap fir up any gen III small block chevy, whether its the 5.3, 5.7, or the 6.0. they all slap around quite a bit when they're cold. Sounds like some good old fashioned MIN-MAX
sjorgens
Oct 1, 2015 07:54 PM
