engine identity
Old Aug 30, 2004 | 08:25 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
engine identity
i need to find some info on my engine. i recently bought a 350 bare block, the casting # is 3970010. what i need to know is can i put hydraulic roller lifters in this engine or not. i want to make this motor a roller motor. is it possible or not?
Old Aug 30, 2004 | 10:52 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You would need a retro-fit roller setup, but yes it's possible.
Old Aug 30, 2004 | 11:06 AM
ede's Avatar
ede
any SBC can run a roller cam, it's just a matter of picking the correct parts.
Old Aug 30, 2004 | 11:09 AM
ljnowell's Avatar
That is probably the single most famous 350 casting in the world. Thats what I have, and many others here. Did you check to see if yours is a 2 or 4 bolt?
Old Aug 30, 2004 | 05:47 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
mine is a 4 bolt main. how much is the retro kit to make this into a roller block or what specific parts woudl i need. this is my first engine build and im trying to gather as much info on it before i screw something up and it becomes costly. plus im kinda broke so its a good time to do research. im thinking about tpi for induction.
Old Aug 30, 2004 | 06:30 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
is your friend. Learn to use it and it shall pay dividends.
Old Aug 30, 2004 | 06:42 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
i have used search and when i sit here for an hour or 2 or 3 or 4, i get rather tired of searching for something, and so i write up a topic and hopefully someone will just give me the answer rather than wasting my time.
Old Aug 30, 2004 | 06:55 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
If you spent 30 minutes on each question and really did use search, you'd have your answer.
Casting numbers:
All of two minutes yielded these, along with a few others which referenced mortec.com. I am not surprised in the least.
https://www.thirdgen.org/techbb2/sho...asting+numbers
Roller retro:
All of another two minutes. Happen to be the TOP TWO returns besides this thread. Gee, surprised? I'm not.
https://www.thirdgen.org/techbb2/sho...fit+AND+roller
So given that I spent about 5 minutes total writing this and running both searches, I must now give you the
Thank you very much for proving my point that can yield you many benefits.
Old Aug 31, 2004 | 09:17 AM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
damn you so smart!!!!!!!!!! i bow down to you.:hail: :hail: sooo smart!!!!! but thanks for the links, made my search a little easier.
customblackbird
Aug 15, 2021 10:16 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
