r.i.p. my 92 tbi
Old Aug 30, 2004 | 08:25 PM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
r.i.p. my 92 tbi
my engine is dying . burns oil and gas like crazy. i took it to 110 mph and the whole car started to shake then at the stop light the problems started to occur. my oil meter was going back and forth everytime i tried to accelerate and would drive when i stepped on the gas, i had to press lightly and ride my way home basically on 20 mph. when i got to a stop i let go the gas and the car started to accelerate by itself up to 25 mph! not to mention the accelerator pedal feels like a brick when i step on it. when i got out, the motor seem to die down when i step on the gas and the smell of gasoline and bad exhaust was everywere. pondering of canceling the insurance and let it sit for a few months while my 88 project is complete. to bad cause my 92 is clean as hell.
Old Aug 30, 2004 | 09:08 PM
CaysE's Avatar
These 92 305s can't hold up to anything that the earlier ones could. Mine bent a rod, I think... all cause I hit 4k rpm with low oil pressure. I mean come on... 4k??
On the plus side... winter project!!!
Old Aug 31, 2004 | 08:03 AM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
did u ever had a problem with your accelerator being to heavy when u stepped on it on yer 92tbi??? mine felt like a brick when i stepped on the gas.
Old Aug 31, 2004 | 08:40 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yea. My '92 with 196K miles on it only runs when I start it.
Old Aug 31, 2004 | 08:49 AM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
Old Aug 31, 2004 | 10:30 AM
CaysE's Avatar
he's being a smartass.
My gas pedal was a little stiff, but I never went up to 25mph without touching it.
Old Aug 31, 2004 | 11:57 AM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
why do these pedals get stiff? does it have something to do with the tbi???
Old Aug 31, 2004 | 12:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes and no. First make sure there is no obvious restriction around the gas pedel on the floor. A corver of a floor mat or worn carpet can do this. The TBI main shaft gets a good bit of gunk and corrosion on it over time. Take off the TBI unit and hose down the throttle spring with carb cleaner (keep it off of the TPS and IAC) and use a toothbrush to scurb it out. Then use some WD40 on the shaft and spring so that it will move freely. I bet you will be suprised.
Old Aug 31, 2004 | 02:40 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
4000 with no oil pressure... What the hell were you expecting???
Old Sep 1, 2004 | 10:35 PM
CaysE's Avatar
4k on an L03 isn't ridiculous. And I said low pressure, not none. Of course it's old and these things happen, but I know for a fact that my 86 LG4 has taken far worse than that and is still keeping me on the road after 165k miles.
Old Sep 1, 2004 | 10:44 PM
25THRSS's Avatar
They're basically the same freakin engine
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
