weird sound???
Old Aug 31, 2004 | 11:38 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
weird sound???
hey guys i have this weird sound coming from my engine everytime i put a load on it. its like a bearing sound. rattaling thing. i think it may be my water pump or AC compressor??? its really bothering my now. seems to get worse!!!
Old Aug 31, 2004 | 12:00 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
it sounds like spark nock to me... try putting 93 octane gas in it and see if that helps if it does then you are just experiencing spark nock.... your timing may be off a bit
Old Aug 31, 2004 | 01:12 PM
430T/A's Avatar
Car: 71 Skylark
Engine: BBB-430
Transmission: M20
Its very hard to diagnose a noise problem without actually hearing it.. Try taking it somewhere..
Old Aug 31, 2004 | 01:20 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
yeah sounds like detonation, preignition, knock whatever you wanna call it, if that is in fact what it is the most likely causes are not enough octane, overadvanced timing, or carbon buildup.
Old Sep 1, 2004 | 12:18 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
so you guys think its a knock. if it was wouldnt my check engine light come on???? ill try to 93 octane with some more octane from autozone.lol i never would of thought of that. i thought for sure it was a bearing. cheap gas!!!!!lol
Old Sep 1, 2004 | 01:58 PM
z28monster's Avatar
Car: 86 IROC-Z
yeah being it only does it when the engine has a load on it.... it maks me think its justspark nock. try the higher octane gas and see what happens. if that helps check your nock sensor or your timeing may be off depending on what engine you have man.
Old Sep 2, 2004 | 10:51 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
i havent put any higher octan in it yet cause i go to school on the weekday and i dont put gas till friday. so i think today or tomorrow i will put some high octan and octan booster. and then when i get home i will check my timing. how do you check your knock sensor???? if i drive like that for too long will it mess anything up??? thanks guys for the help!!!!
Old Sep 2, 2004 | 11:48 AM
z28monster's Avatar
Car: 86 IROC-Z
yes over time detonation can cause damage
Old Sep 3, 2004 | 12:39 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
hey thanks alot guys that was the problem. i went to autozone and got some gas treatment and 104octan stuff and went to 76gas station and put the highest one in my car and in about 20 minutes or less my car was running alot better.. THANK YOU GUYS YOU SAVED MY LIFE!!!!!! i thought it was much worse than that. no more cheap gas!!!:lala:
Old Sep 3, 2004 | 04:26 PM
89RsPower!'s Avatar
glad to hear thats all it was, gotta watch where ya get gas sometimes
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
