Quick timing question.....
Old May 3, 2001 | 04:25 PM
Dan87IROC-Z's Avatar
I timed my car the other day, I set it at about 14* advanced with the EST disconnected, does that sound about right, or should I go for more?
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old May 3, 2001 | 04:28 PM
Bort62's Avatar
Sounds perfectly reasonable, Does it Ping ?
if not, Go for more! )
Altho< if you get to Much your knock sensor is gonna start playing games with your Head.
Im Not to Sure what the best procedure is with the TPI.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -&gt; My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 4, 2001 | 03:45 PM
What does ping/detonation sound like, will I know for sure when I hear it, or is it something I will have to look for?
L98 TPI 350 (5.7L)
Old May 4, 2001 | 04:12 PM
ede's Avatar
ede
best way to check for ping is with a scanner since you have EST. most people refer to ping as "the valves rattling"
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 4, 2001 | 04:15 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
ping sounds like something in your engine rattling around.. sorta like the sound you would get if you were clanging a wrench inside a small can... weird thing is, it sounds nothing like ping, more like a rattle..
stock TPI should be around 6 BTDC
here's a link to a timing article i wrote: http://www.iroc-z.org/tech/distributor/settingtiming
Webmaster: www.IROC-Z.org
Infested
May 22, 2018 11:56 PM
crazynights
Aug 21, 2015 06:53 AM
happyhapka
Aug 15, 2015 04:42 PM
