oil dipstick smokes?
a stupid question i know, but it smokes a little out the dipstick, anything i can do about it?
91 z-28
t-tops
305 tpi
k&n filters
tb bypass
auxilary fan switch
more to come...
91 z-28
t-tops
305 tpi
k&n filters
tb bypass
auxilary fan switch
more to come...
Don't check your oil while it's hot? hehe
If it does it while you're engine's on, then your dipstick isn't going all the way in place.
It's not really a big deal, I work at JiffyLube and every car there smokes when I check/change the oil on a hot car. So long as you don't mean smoke is billowing out of it like a steam engine.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
Don't think I'm trying to insult your intelligence here D'sZ-28, forgive me if it comes out that way. The replies that I've read so far sound correct. But, if when you're checking the oil on a hot engine sometimes oil can drip onto a hot exhaust manifold/header and cause smoking near the dipstick tube. Just something else to check.
not insulted a bit, i love this place, and just bought the z a month ago after having a a 95 s-10 for the last 5 years that i never had to do any work on,so all this tpi stuff is new to me,no after a normal drive i pop the hood and i got a steam trail coming out of the dipstick tube,nothing major i guess i was just wondering,maybe i need another tube that seats better?thanks for the replies
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Put your finger over the dipstick tube while the engine is running. If it builds up pressure then you're getting excessive blow-by past the rings. The PCV should pull most of it back into the engine. Check to make sure it's not plugged. Other than that it sounds like you need a re-ring.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
