?'s about changing engine mounts
Old Sep 12, 2004 | 01:21 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
along with everything else, i need to change the engine mounts also, but apparently there are nuts on the underside of the crossmember, so how does one get to those? is it necessary to drop the lower control arms?
KAM
Old Sep 12, 2004 | 02:37 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yes there are nuts under there and no you dont need to drop that lower arm
all you need is a friend to hold a 15mm swivel socket on a bunch of extension on the nut with the car jacked up from underneath then remove the bolts from the top with an impact or ratchet easy as pie
we did it on ljnowells car when we switched to a v8 from a v6 it only took about 1/2 hour or so to do with two people if you dont have a 15 mm swivel socket then you can do what we did and took an old 15 mm box end wrench and heated it up and bent it to the right angle we needed and used it
Terrell351
Jun 13, 2021 01:13 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
