My New Top End...
Old Sep 15, 2004 | 01:49 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My New Top End...
Well, lots of you guys have probably seen the threads about all the $hit I've been going through with this car lately, but it all worked out for the better! I got the oil pump fixed, got it mostly tuned right, and it runs like a top.
I know some of you are gonna knock my choice of intake, but as Five7 always says "run what ya got" and thats what I had. I like it too... low end grunt feels the same as stock, but its got a REALLY nice high rpm howl now!!
Is it really necessary to change the vacuum hose for the brakes to a steel line though?
Old Sep 15, 2004 | 01:51 AM
Air_Adam's Avatar
Another...
Old Sep 15, 2004 | 01:53 AM
Air_Adam's Avatar
BTW - for those who don't know what I was talking about with the oil pump, heres a pic of what I found when the pan came off.
(HINT - look at the slot where the driveshaft connects to the pump)
Old Sep 15, 2004 | 01:56 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I've seen that before....
Nice engine. I think thats the first time I've ever seen the alt. fan painted the same as the water pump/block
Old Sep 15, 2004 | 10:17 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Nice looking setup!
As for your question - no, the power brakes vac line does not have to be metal (in fact, I've never seen one that was)
Old Sep 15, 2004 | 05:35 PM
Air_Adam's Avatar
Originally posted by vernw
Nice looking setup!
The stock line going to the Qjet was steel up to the check valve, and rubber hose after that.
So it is fine to use just rubber like I did?
Old Sep 15, 2004 | 08:26 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
id say so thats the way they came from the factory if you replaced the factory rubber line just make sure its as thick as the factory stuff as in wall thickness
Old Sep 15, 2004 | 11:41 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
AFAIK, you couldn't have screwed that metal brake booster line into the back of that carb anyway, so it's a moot point. Rubber hose is fine.
Looks nice!!
BTW...what happened to your L69?? Is it just me, or does it seem like a lot of us have switched out the L69's lately?
Old Sep 16, 2004 | 12:26 AM
Air_Adam's Avatar
L69 is on the engine stand right now
Old Sep 16, 2004 | 12:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I must have missed what happened to your oil pump.
Old Sep 16, 2004 | 02:58 AM
Air_Adam's Avatar
My theory: It somehow basically hydro-locked and snapped the two teeth off of it.
But I got a new pump in there now, and it works beautifully. At running temp, its got about 35lbs at idle, around 60 at WOT.
Old Sep 16, 2004 | 05:50 AM
five7kid's Avatar
More likely it got a chunk of something in there somehow. Did you weld the pick-up tube on?
Glad you figured it out, though.
Old Sep 16, 2004 | 12:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
What a coincidence - That's where mine is!
Old Sep 16, 2004 | 01:06 PM
Air_Adam's Avatar
Na, the pickup was brazed on. And thanks
Old Sep 16, 2004 | 01:25 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Is your engine supposed to be blue? I thought they were supposed to be black, tho I did paint mine orange like an old chevy
Old Sep 16, 2004 | 02:09 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
That looks better than stock for sure! Now you need to put on your headers and get something to properly route your spark plug wire.
The track is only open this weekend and next before it closes if you were thinking of taking it down the 1320.
Old Sep 16, 2004 | 05:12 PM
Air_Adam's Avatar
Hmm... Maybe I should take it out to SIR... might be fun
Old Sep 16, 2004 | 09:18 PM
rjmcgee's Avatar
Your gonna melt your spark plug wires.
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Nice! just get rid of that paper edelbrock air filter and get you a nice K&N
Old Sep 17, 2004 | 01:13 AM
Air_Adam's Avatar
Plug wires have been rerouted, and they are now really purdyful, and won't burn up!
Old Sep 17, 2004 | 10:08 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
I am going out tomorrow morning at about 8:00 am. Its a points race but you can run in S/L with the rest of us F-Body guys. Do you work Saturday or/or Sunday?
Old Sep 17, 2004 | 01:53 PM
Air_Adam's Avatar
I don't work tomorrow or sunday, so maybe I'll try to get out there.
Whats it cost to get in to race?
Old Sep 17, 2004 | 01:56 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Its $20 a day to race in SL. You get 3 hits in the morning and then setup into the brackets. If you decide to go and want to meet at my place and head out together let me know.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Nick McCardle
Sep 10, 2015 08:36 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
rsrookie
Sep 5, 2015 07:08 PM
