blower motor hose
Old Sep 15, 2004 | 08:49 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
blower motor hose
there is a hose about 6 inches long coming off the side of the heater blower motor. Is this supposed to be connected to the male adapter on the housing by the firewall? mine is not attached. what will this affect?
Old Sep 15, 2004 | 10:53 PM
ljnowell's Avatar
heater blower motor
There are no hoses running to the blower motor, only electricity. Depending on year, and style of engine in your car, it is set up 1 of two different ways. Either there is a hose coming off of the water pump, and one of the intake that both connect at the firewall. The second way has a hose that goes to the radiator (I think it is only one, as I have never owned one set up this way), and another to the waterpump I think. BOth connect at the firewall also, to circulate coolant through the heater core.
Old Sep 16, 2004 | 05:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a little rubber hose that goes from the high pressure generated by the blower, to the back of the motor, right by the brushes, for cooling.
If it's not there, the motor will probably burn up just that much faster.
Old Sep 17, 2004 | 09:41 AM
trueburton's Avatar
thanks RB, that would make sense but the hose is on the pass. side and the male part on the firewall is on the pass side of car but on the opposite side that the hose comes from.
Old Sep 17, 2004 | 07:14 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Turn the blower motor around....should line right up.
Old Sep 19, 2004 | 05:59 PM
trueburton's Avatar
i have tried that and the hose does line up but the mount screws do not. Why would this be like this?
Old Sep 19, 2004 | 07:03 PM
406TPI's Avatar
Car: 1985 IROC-Z
Do you have A/C?
If the holes don't line up, you can actually drill new ones, it won't hurt anything.
Old Sep 19, 2004 | 08:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You probably have the wrong hose, or the wrong blower motor..... some one that's exactly the same as the right one, except different.
Old Sep 19, 2004 | 10:40 PM
trueburton's Avatar
yes i have A/C although it doesn't blow cold
Old May 17, 2013 | 09:59 PM
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Re: blower motor hose
Since we all love bringing threads back after more than nine years of being dead, where can I get this little hose from? I have a feeling this is causing a problem in my car. On hot 90*+ days, my blower will run on high for about 3 minutes before slowing way down to almost nothing. I'd describe it like the blower overheats but have no way of knowing. I have never had this hose on my car and the blower motor is only two years old.
P.S. I searched and found nothing but this old thread.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
