why wont it start
Old Sep 17, 2004 | 11:29 PM
taylor91rs's Avatar
why wont it start
About ebery other time i try to start my car when i turn the key it just humms. Then if I wait about five minutes it will start right up. It does this in the rain and the sun and cold and hot . I replaced the starter but that was not it cayse it sstill does it,
PLEASE HELP IT IS VERY FRUSTRATING
Old Sep 18, 2004 | 04:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What type of engine?
Old Sep 18, 2004 | 04:21 AM
sellmanb's Avatar
Car: '86 Berlinetta
Does it do it right after you park the car? Or even in the morning when it hasnt been started for several hours, or.... ?
What is the typical scenario when this happens? I'm thinking heat soaked starter, and replacing it didnt help much because it's still being heat soaked.
Old Sep 18, 2004 | 09:26 AM
taylor91rs's Avatar
it is a 305 tbi engine. IT does it at all times wether it has ben drivin for a while or even in the morning.
Old Sep 18, 2004 | 10:23 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Where does the humming sound like it is coming from and does your security light stay on until you release the key?
Old Sep 20, 2004 | 09:58 AM
taylor91rs's Avatar
yes the security light turns on until i release the key
It sounds like the humming is comeing form behind the dash
Old Sep 20, 2004 | 10:03 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It sounds like you are having a problem with the VATS system. What can of shape does the contacts on your key and the lock cylinder appear to be in? Maybe dirty or worn?
Old Sep 20, 2004 | 02:07 PM
taylor91rs's Avatar
THe key is really worn
would replaceing it fix my problem
Old Sep 20, 2004 | 02:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
More than likely it would because if the key is worn, the contacts in the lock cylinder can't read the resistance value in the pellet.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
