What does it mean when black deposits is coming out of my exhaust pipes
Old Sep 25, 2004 | 01:43 AM
91NiteRida''s Avatar
Car: 1991 Camaro
As the subject says.....what does it mean when black carbon deposits is coming out of my exhaust pipes at start up??Is it my heads?valves?both?Will it effect my smog check when i go in later this month?All and any info will be greatly appreciated
Old Sep 25, 2004 | 07:09 AM
ede's Avatar
ede
you mean like chunks of black stuff?
Old Sep 25, 2004 | 11:20 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
if it looks like smoke then its running rich.
Old Sep 25, 2004 | 11:49 AM
Car: 1991 Camaro
Its little specs of black deposits...its not really black smoke but little specs of black somethings lol
Old Sep 26, 2004 | 09:43 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I think what you are seeing is water condensation mixing with the carbon deposits in the exhaust. In my opinion this is normal and goes away as the exhaust system heats up. For your smog check you want your car at it's normal running temperature. So make sure it is warmed up. Allen
Old Sep 27, 2004 | 01:56 AM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Old Sep 30, 2004 | 03:08 AM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
carbon build up in the heads
Old Sep 30, 2004 | 03:23 AM
Car: 1991 Camaro
i have to agree with you...what is the fix for this??new heads?and i think this is why its throwing codes 32,42 and 45...it says im running rich...and then im not getting enough spark
Terrell351
Jun 13, 2021 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
