Got spark, but no Start! pleez help :D
Old May 14, 2001 | 11:32 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
this past week ive been installing hooker LTs, with no experience. it was tough. anyways i got em in, hooked up the starter and all, and go to start it and no luck. so i get some starting fluid and i jump teh solenoid with a spark plug and boom, it starts up for half a second, and shuts off, key was in on position.
so i know i have spark,
so...here are the symptoms, car doesnt crank with key, injectors dont fire, fuel pump doesnt prime (not vats, its bypassed, and vats will let the pump prime)
also..i checked all teh fuses under dash, is there a fuel pump fuse somewhere? also, ignition switch is fine cuz all the accessories work in ON position.
what u guys think?
also...i had removed MC and booster, so i was under the dash messin around movin wires n stuff, i also have an alarm that seems to be workin fine.
pleeeeeez help....thanks Rick
305tbi
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
[This message has been edited by Black Beauty (edited May 14, 2001).]
Old May 15, 2001 | 12:17 AM
Vader's Avatar
Possibly the fuel pump/ECM fuse? Check near the radiator and battery for an inline fuseholder.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 15, 2001 | 12:25 AM
Car: 90 Camaro RS
Engine: 305 TBI
ill look around, but there IS a inline fuse from the hot lead screw that goes towards the starter, but its good...and the terminal is hot at the starter....soooo i dunno
edit: i forgot to mention i had to remove the brake booster to get headers in, and was under dash removing nuts, i could have loosened wires under there, a friend mentioned a Crank wire that gives power to fuel pump and solenoid....
Old May 15, 2001 | 02:20 AM
Slow Iroc's Avatar
vaders first guess would be mine as well. I know of the MAF cars it can be found right by the engine coolant reserve. It will be attached to the fender by a bolt or plastic hold tab. You need to address why the fuel pump isn't priming...I say the problem is in the fuel, obviously not spark or air. If you check under the dash, and see no pinched wires, then check the relay for problems and turn up with nothing, put the car up on four jackstands, and find the harness lead that runs back to the fuel pump. Have a friend turn the key, while you check for current. Consult a service manual for wire color information. If you have current, the problem is behind that (the pump itself?), if you don't have current, trace your way back through the entire electrical system untill you find out where the current flow stops, and there is your problem area.
Gee, then again, you don't have to listen to me, because it's obvious I know nothing about cars, ROFL, particularly the Fbody.
Old May 15, 2001 | 02:27 AM
Car: 90 Camaro RS
Engine: 305 TBI
thanks...but what was that last part about dood?
it wasnt needed...
go to musclemotors, compare prices for parts for a camaro vs a mustang, mustangs are more expensive....my friends have them and they are WAY more expensive to maintain.
3rdgen camaros may have come from the factory kinda slow or disadvantaged, but thats cuz most were the economical 305tbi that i have. the 350tpi was by no means slow, even the guys at stangnet readily admit that....why wont you? ok wanna compare newer ones? LS1 vs 4.6....nope, mustangs lose by an even bigger margin, even with their true dual exhaust , maybe if the hood was functional, they could atleast make it interesting.
once again, thanks for your help with the pump, but i thought id share my opinion on mustangs
Old May 15, 2001 | 02:29 AM
89ProchargedROC's Avatar
if the fuel pump in line fuse was blown the car would still crank but not start.
the in line fuse holder is in between the radiator and the battery for the fuel pump.
maybe there is an in line fuse for the starter
Old May 15, 2001 | 03:11 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I agree.
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old May 15, 2001 | 03:25 AM
Car: 90 Camaro RS
Engine: 305 TBI
its not that.
i think its that "CRANK" wire...
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
djmarch
Aug 19, 2015 12:07 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
