Sticky/Locked up Alternator
Old May 15, 2001 | 06:42 PM
UberTA's Avatar
How can I fix this? Do I have to replace/rebuild my alternator? My accessory belt broke because my alternator was hard to turn, and it smoked it, is there an easy way to fix this?
Old May 15, 2001 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends on what alternator you have. The older style 10SI ones are easy to rebuild. The newer ones as designed to be replaced instead of rebuilt.
Depending on what's wrong internally, it'll probably be cheaper just to get a replacement one with a warrenty.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old May 15, 2001 | 09:22 PM
Enkil's Avatar
I'd just go ahead and replace it. If you take it to Advance Auto or Autozone or something it shouldn't cost you more than 100. (After you bring back the defective one.)
Granted, you're not going to get much value out of those, but they work. heh
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
