Quick intake help please...
Old Sep 29, 2004 | 05:23 PM
92GTA's Avatar
I just got my Accel intake and it has 3 large threaded holes on the front of it. I know the 2 toward the center are for the coolant and the temp sensor but what is the 3rd one off toward the passenger side for?????? I don't remember that being there on my stock intake?
Thanks!
Old Sep 29, 2004 | 05:27 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
I have the same intake. For our cars it is not needed, so just plug it.
Old Sep 29, 2004 | 05:35 PM
92GTA's Avatar
Thanks. Off to the nut and bolt store then...
Old Oct 3, 2004 | 08:43 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
The third one is the cold start injector sensor. Only needed for 85-88 applications. If the temp is under a certain temp (don't remember what it is), then this sensor tells the cold start injector to fire on startup. Not needed on '89-up cars..
Old Oct 3, 2004 | 09:48 PM
92GTA's Avatar
Sorry, I wasn't talking about the cold start. This was another threaded hole that opened into the coolant passage in the front of the intake...
Old Oct 3, 2004 | 10:09 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I'm not really sure what they are, but I just checked on mine ('86 TPI) and the top one is coolant hose and the bottom two are both sensors. I bet Clocker is right, you probably just need to plug one if your wiring harness doesn't have a hookup for it.
Old Oct 3, 2004 | 10:12 PM
92GTA's Avatar
Yup I used a 3/8" hex head stainless plug for it. I used thread lock and threaed in until it was flush. Look great....
Old Oct 3, 2004 | 11:37 PM
Car: 1997 Corvette
Exactly.. :lala:
Its the sensor that tells the cold start injector (located on the intake manifold, plugged into the fuel rail and the wiring harness) to fire for a maximum of 8 seconds if it detects a coolant temperature of under 100*F (researched it after my first post).
'89-up cars do not have this, nor do they have the CSI on the intake manifold nor the wiring plug or fuel line for it. In the '89-up cars, they use a longer injector PW for cold starts.
Old Oct 4, 2004 | 12:48 AM
92GTA's Avatar
I feel like a dumbass, I didn't even see the last half of your post mentioning the temp sensor. All I saw was cold start injector
I'm sorry dude...
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
