Connecting starter
Old May 15, 2001 | 08:18 PM
Alan84TA's Avatar
Connecting starter
I've had my engine out awhile and can't remember where the starter wires go. There is a black wire from the battery that goes to the big terminal? then three red wires from behind the engine block that go?? I think 2 of them have large connectors and the third has a small connector. Do all 3 red go to the small and the one black to the large terminal?
Old May 15, 2001 | 11:07 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
the three red and the large black go to the large terminal...the thicker (about 8 guage) with the small connector goes to the small.
Old May 16, 2001 | 08:13 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Just curious as to why you have a black cable from the batt to the starter. Usually black would be the negative cable off the batt, and RED would be the positive cable off the batt going to the starter. Also, there are 2 small terminals on the solenoid, and the wire with the small terminal will connect to the "I" terminal on the solenoid, not the "R".
KAM
Old May 16, 2001 | 12:49 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Well I don't know, mine's an 89 and the batt cable is black, the smaller terminal wire is black, and the others are red. On my solenoids the terminals are "R" and "S" and "S" is the one that the small-terminal wire connects to. Were they different for different years?
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
Cleotiz
Sep 16, 2015 08:02 AM
Magman
Sep 13, 2015 12:07 AM
Formula_88AE
Sep 3, 2015 01:47 PM
