starter metal tube for wires
Old Oct 8, 2004 | 06:19 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
anyone have a diagram or photo or description of how the metla tube that protects the starter wires from the exhaust bolts up. mine has been apart for so long i can not seem to see the proper way to mount it
thanks jeff
Old Oct 8, 2004 | 07:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't recall any conduit for wires on my '89...sure you're not thinking about the tube that goes to the cat?
Old Oct 8, 2004 | 10:53 PM
JeffW's Avatar
Engine: 305 tpi LB9
positive it has wires in it and always has tube for cat is gone since no more air pump. it protects the wires from the heat of the exhaust manifold
jeff
Old Oct 8, 2004 | 11:05 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I know the tube you refer to; my car had one. I just don't know how it was bolted up
I'm sure that helps a lot..
Old Oct 9, 2004 | 01:19 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
one bellhousing bolt. you'll figure out which one.
Old Oct 9, 2004 | 08:14 AM
Damon's Avatar
What JDM said- one bellhousing bolt. Other end of the tube often looks like it has a flange to bolt onto the starter (some applications) but, in fact, bolts to nothing on that end. Just hangs out in the breeze on the other end.
Old Oct 9, 2004 | 11:19 PM
jmd's Avatar
jmd
I am not Japanese Domestic Market.
Old Oct 9, 2004 | 11:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Originally posted by Damon
What JDM said-
That's got to be one of the cruelist insults possible for this site
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
