How do I figure out how much my speedometer is off with bigger tires????
Old May 18, 2001 | 09:11 PM
CamaroX84's Avatar
I have the correct speedo transmission gear piece for my rear end and for stock IROC 16" rims. But the previous owner has some pretty "non low profile" tires on there. Consequently, they have a larger diameter than stock. Anybody know where I can punch in my new tire size and find out how much off the speedometer is? Any help would be much appreciated. Thanks.
Old May 18, 2001 | 09:22 PM
poncho9789's Avatar
Go to equations on the main page of thirdgen
Old May 18, 2001 | 09:23 PM
72Formula400's Avatar
When I put some Lo-pro's on my car, i just drove next to a friend and we matched speed and he yelled out how fast we were going. Hopefully his speedo reads correctly. It's not totally accurate, but you get an idea anyway. It also affects your odometer too. I didn't realize that at first, but now I know. Anyway, hope this helps some.
Tom
Old May 18, 2001 | 10:14 PM
CamaroX84's Avatar
How does it affect your odometer? Thanks.
Old May 19, 2001 | 12:25 AM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Odometer is running off the same gears as the speedo, thus like in my car when I go ~45 my speedo reads 65, so when I have gone 45 miles, my odometer will have counted out 65 miles. (Doh!) Oh well, I know my odo was off when I got the car since it had those 4.10's in it which I stripped out...now has 3.73's
Old May 20, 2001 | 12:58 PM
87rustybluebird's Avatar
if you know the outside diameter before and after it it easy. lets say you went from a 26 od tire to a 25, figure out circumfurence of both, then divide to get a ratio, then aply it to your speedo.
Old May 20, 2001 | 01:34 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Go to this link
http://www.intercotire.com/calculators.htm
Change the tire size from metric first then use the MPH calculator.
Hope it helps.
[This message has been edited by Ozzy88GTA (edited May 20, 2001).]
Old May 20, 2001 | 03:00 PM
82camaro's Avatar
Car: 82 camaro SC
Keep in mind that it isn't a specific number. It's a percentage. The faster you go the farther off it is. If it's 10 off at 50mph, it's 20 off at 100mph.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
ChevyZ71
Aug 13, 2015 07:30 AM
