For anyone who ever had a cracked block...
yup mine is like that but worse the side collapsed in the cylinder. I am taking it in for machining tomorow thay said that they could sleave the block.
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Trans, yes you are in deep sh@#. On the plus side it looks like a repair is possible. I see it this way, it might be an opportunity to build another engine and add some goodies to a fresh block. Good luck.
When I took the block in to be machined my machinest told me that sleveing the cylinder was more than possiable to sleve my block and that he has fixed much worse. Plus I am going to have my heads ported and the bottom end is going to be re-balanced. hopefully I will get my parts back before next month (my machinest is a little behind on his work).
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm getting a cylinder sleaved right now. If I could afford it, I'd get them all sleeved. There are many race engines in town that have all 8 cylinders sleaved.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.69
Best MPH on a time slip: 121.52 altitude corrected to 127.76
Altitude corrected rear wheel HP based on power to weight ratio: 504.5
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
