Heads for a daily driver??
Old May 18, 2001 | 10:53 AM
scott87conv's Avatar
what type of heads is best for a daily driver on a 400sbc alumnium or cast iron. Want to run 9.5comp and was thinking of thr edlebrock rpm preformer package??
Old May 18, 2001 | 03:52 PM
ede's Avatar
ede
i don't like edlebrock parts, but that's me. i'd run iron heads for 9.5 compression and on the street.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old May 18, 2001 | 04:00 PM
Polecat's Avatar
I like the Edelbrocks as well as the Dart Pro 1's and AFR's. But if you decide to do the RPM "package", do not use the cam that comes with it. Get a Comp Extreme cam....alot better cam IMHO.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old May 20, 2001 | 02:01 AM
jaretz28's Avatar
Nothing wrong with Edelbrock. Just everybody seems to want them and they don't bother researching any others. Like for instance:
Canfield Cylinder Heads makes a pair for 400 sbc with the steam holes. I have no price but the have the same specs as the over rated Edelbrock's and probably 3/4 the price. There aluminum so you need a good head gasket to avoid leaks, but you save like 50 - 80 lbs over the irons.
Old May 20, 2001 | 07:42 PM
Thanks everyone,jaretz28 i didnt know about canfield.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
NWAsonoma
Aug 18, 2015 05:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
