L98 and LB9 cams, same or different?
Old May 20, 2001 | 08:14 PM
BlackBird305's Avatar
I can't really find the answer anywhere so i hope someone can set me straight...i heard the L98 cam is the same as the Lb9 5spd cam and the Lb9 auto came with a different cam...any truth to this?...thanks guys
91 Pontiac Firebird...305 TBI
black, t-tops, auto
K&N 14x3 open element air cleaner, 3 inch high flow cat, 3 cat-back into a flowmaster 80 series, IAT Resistor, ultimate TBI mods, Hypertech Thermomaster Chip, TC lock-up switch...SOON TO COME...SLP Torsen Posi unit w/3.42's or 3.73's and Edelbrock TES headers
System..Kenwood 45x4 head unit, Pioneer 5.5 3-ways, Infiniti Kappa 6x9's, Two JBL 10's in a sealed hatchbox, Two Kenwood 350 watt amps
Old May 20, 2001 | 08:24 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Yes you are right the lb9 manual got the same cam as the l98 did. Yes the lb9 auto got shafted with a cam commonly refered to as the peanut cam. Thus the reason I have an LT1 cam in my car now. I'm am almost a sec faster.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials, and 170* Stat.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.72 @ 92.1
“Fallen But Not Forgotten”
Old May 20, 2001 | 08:51 PM
Guest
Guest
Posts: n/a
It depends on the year as well. The best way to know is to check the cam lift.
Old May 20, 2001 | 09:32 PM
Vader's Avatar
New,
Have you tried the 1.6:1 roller rockers yet? I seem to recall a thread with that possibility.
I see by your sig that the drag radials did very well for the times. Not bad for stock injectors and plenum, and a factory PROM. I smell a low-14 on the way...
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Old May 21, 2001 | 12:44 AM
Bort62's Avatar
new, your Times are very Close to mine w/ Lg4 + Comp 262H.
The Drag radials Gave you Three tenths ? how High Were you Launching ?
That looks promising
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Jorlain
Oct 8, 2015 01:57 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
