indicator problem!
Old Oct 12, 2004 | 02:17 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
indicator problem!
Whenever I turn on my indicator for either a left or right turn, it just stays on but do not blink, what could be the problem and how would I fix it? thanks guys
Old Oct 12, 2004 | 02:31 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What doesnt come on? The lights outside the car, or on the dash? both?
Could be as simple as a blown fuse, and probably is.
Old Oct 12, 2004 | 02:40 AM
both lights on the dash come on also the outside ones, its just that they all stay lit without blinking.
Old Oct 12, 2004 | 03:03 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Try replacing your signal flasher! But first, confirm that all bulb's are working. Your car's system is designed to warn you that either
1, indicator will not blink if a bulb is blown. 2, indicator's will not blink in either direction if flasher is worn out.
Old Oct 12, 2004 | 06:51 AM
bobsroc's Avatar
Car: 1987 IROCZ
Bad bulb/bulbs or wrong bulb plugged in somewhere. Bulbs for turn signals are dual element, make sure that what you have in there.
pjsparts
Oct 29, 2025 06:39 PM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
