battery cable ques
Old May 20, 2001 | 08:05 PM
jmon92conv's Avatar
battery cable ques
I know this sounds stupid, but..
I have to replace my battery cable and was wondering if the TPI cars were different than the TBI cars. It is on a 92 Z TPI. I bought a new GM unit and I think it is for a TBI but GM could have replaced the orig unit with this one. Any ideas?
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old May 20, 2001 | 08:27 PM
bhaas's Avatar
As long as the cable reaches and bolts up with no problems, it should be fine. It's just a cable.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
Old May 20, 2001 | 08:30 PM
jmon92conv's Avatar
not just a cable, it has a plug on it my old one does not and a different flusable link.
Jeremy
Old May 20, 2001 | 09:07 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i just got one at the parts store for 11 bucks, it had a loophole at the starter end, and a side terminal and then a smaller wire with a loophole to go to the lil post near the battery and radiator. it was exactly the same as mine. it said OEM style. its teh same for TPI and TBI. id try that out.
Old May 21, 2001 | 04:03 PM
Mike89GTA's Avatar
I'm replacing my positive battery cable and starter today too, the one I just got from Super Trak is nothing like the stock one, it's not even long enough The part number is ST65-4R.
Does anybody know the correct guage of the factory one? This one is 4 guage and it's not nearly as big.. plus the factory one has a fuseable link coming off it and has the alternator wire "built in." I just called the dealer and a new positive cable is $84!
Old May 21, 2001 | 04:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AC/Delco part # A35-4DA
about $18
ICON Motorsports
Old May 21, 2001 | 04:19 PM
Car: 90 Camaro RS
Engine: 305 TBI
you probably got the universal one. You need to get the OEM style one...if super trak has one.
MM2Robinson
Oct 1, 2017 09:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
