Installing pistons, will be sitting for awhile Q
Old Oct 16, 2004 | 09:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll be installing a set of pistons tomorrow, the block will probably be sitting for another month or two before I even get a chance to install it and fire it off.
Normally I'd wipe the bores with 30wt, but since it's going to sit for so long, should I use assembly lube or something similar?
No, not a SBC, oiling characteristics are completely different.
Old Oct 16, 2004 | 10:36 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just oil should work fine, it just has to coat the bores so they dont rust :shrug:
Old Oct 16, 2004 | 10:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, that's what I was figuring on doing, but have seen many use some sort of white grease/lube in the bores for engines that would be sitting for awhile, just wondering if it was necessary or not.
Old Oct 16, 2004 | 10:46 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
you should only have to coat it with oil and then bag it and it should be fine just make sure you wipe all the machined surfaces also so they dont rust ....
Old Oct 16, 2004 | 10:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Cool, 30wt it is
Old Oct 16, 2004 | 11:03 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I put duct tape over my deck when it sat for a bit, a bag will suffice. Shot of oil now, and then some later is what I did.
fasteddi
Sep 2, 2015 10:29 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 07:57 PM
Fronzizzle
Aug 17, 2015 02:52 PM
