Distributor End Play
Old Oct 18, 2004 | 10:22 AM
87camz28's Avatar
Car: 1987 Camaro Z28
Engine: 5.7L, L98 slightly modified
I am converting from a TPI to Carbed engine in my 87 Camaro. I removed the computer controlled distributor and have changed the gear on an older rebuilt non computer controlled distributor. When I compared the end play or slop of the non computer controlled distributor to the computer controlled distributor, I noticed that the non computer controlled distributor had a good bit more end play or slop in it. Is this normal and just the difference between the 2 types of distributors, or should the end play for them be the same? If I need to shim the distributor, does anyone know the specs on the amount of allowable end play?
Thanks in advance.
Old Oct 18, 2004 | 11:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some end play is normal. Seems like most factory distributors have rather alot, and not consistent at all from any one to any other.
I like to shoot for something in the .015-.020" range.
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 07:57 PM
86White_T/A305
Aug 17, 2015 12:16 AM
gwade12
Aug 8, 2015 08:17 AM
