Lost only Key
Old Oct 18, 2004 | 08:50 PM
Sagan87's Avatar
Lost only Key
EDIT
Old Oct 18, 2004 | 08:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
VIN > Dealer > Code cut a key. If they tell you they can't call another dealer, I just had a set cut on an '89 GTA this past spring.
Otherwise look up the article to get the VATS bypass stuff, or go to SEthirdgen.org, IIRC Bernard has an article there for it as well. Pull your ignition cylinder and bring it to a locksmith, who for about $15, will cut you a new key.
Old Oct 18, 2004 | 09:52 PM
Sagan87's Avatar
EDIT
Old Oct 19, 2004 | 01:12 PM
Sagan87's Avatar
Really, Help?
EDIT
Old Oct 19, 2004 | 02:27 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Originally posted by Sagan87
See. the problem is, i went to the dealerships, they said that they couldnt get the VAT# and that they couldnt find out where the original dealership was that sold it. I know the car is out of Missouri. The problem is, I could do the resitor thing, but I do not even have a key for the tumblers. Is there any wire combination or sequence of events that i could use to start my car? kind of like just making it a push button start?
They (the dealer), is 'ing you. I lost my only ignition key last year. I had to have the car towed to the dealer. They had a Kent-Moore VATS Interragator which they hook up to the car to figure out which resistor value (#'s 01-13) it is. Then they just cut a new key with the proper resistor -- i think it cost about 100 bucks.
I'd suggest trying another dealership, they either don't know what they're talking about or are unwilling to help.
Old Oct 19, 2004 | 02:54 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
You are really making this harder than it is. Did you even read my previous post?!?
Put the car in neutral manually from under the car. Move it.
Pull the ignition and get a key cut. Then bypass the Vats.
-OR- Call a different dealership and get a code cut key- THEY CAN DO THIS!! If you have -that- much of a problem, give me the vin and I'll see if I can get anyone at a dealership up here to do it. Cripes.
Old Oct 19, 2004 | 03:24 PM
Sagan87's Avatar
EDIT
Old Oct 19, 2004 | 03:39 PM
ridecamro's Avatar
Car: 91 rs
Engine: 250
Axle/Gears: stock??
push botton a start is very simple. all thier is mounted on your stearing colum is a igniton switch. the key goes in and turns the cylder . all that does is move a rod that attaches to the igntion switch. and all this does is pull a metal plate back and forth to conect the 2 sides of the wire. just look up in your chilton which is the starting wire. and which and run acc. and so on. then make swithces and that their you go but the other thing is your gonna have to ethier
A) hit your steering clum with a hammer really hard to break it loose.
b)get a key made.
you don't ahve a key. which leaves us with A . lol so enjoy all it is . is a pin holding the stearing wheel form moving so have fun
Old Oct 19, 2004 | 03:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
https://www.thirdgen.org/techbb2/sho...hreadid=113811
That';s just one thread. There are a bunch. If you are going to bypass the VATS then you can just go buy a new cylinder for $15-20. Search up and you'll find the info you need.
Old Oct 19, 2004 | 03:53 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Oh, and a whole slew of locksmiths make housecalls for some extra money.
Old Oct 19, 2004 | 09:29 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Every ignition i ever bought came with the instructions on disassembly and assembly of the new cylinder. Of course you'll need to pick the lock and have the cylinder in the run position to get it out.....If you want some pointers on picking it open..shoot me a email...don't want to say it on here, might get fined and lose 25 points
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
3.8TransAM
Sep 27, 2015 08:37 PM
