car is floored.. shifts at 6800 rpm in first not good
Old Oct 19, 2004 | 06:51 AM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
there anyway i can fix this?
Old Oct 19, 2004 | 10:00 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Not to get off topic, but did you finally get your car painted? looks great!
Old Oct 19, 2004 | 10:09 AM
kptkid's Avatar
The transmission cable that comes up to the where the throttle is connected adjusts the pressure in the trans. if it is not set right it wont shift at the right time.
Old Oct 19, 2004 | 12:06 PM
IROCBlueZ28's Avatar
If you have an automatic transmission, search for transflexio's method of adjusting the TV cable. works perfect every time!
Old Oct 19, 2004 | 05:27 PM
Car: 2002 SS
Engine: Ls1
can anyone show me where this cable is? and what to do to it.. and yeah my car is finally painted lol
Old Oct 19, 2004 | 05:50 PM
sellmanb's Avatar
Car: '86 Berlinetta
crazy, your car looks great you did a great job on the body work. If you look at your tranny, on the driver's side (I believe) there's a little throttle linkage looking thing. Examine it and play with it, you'll figure out fairly quickly how to adjust it.
Old Oct 19, 2004 | 05:55 PM
Car: 2002 SS
Engine: Ls1
oh alright cool..someone actually noticed my paint other then me saying "I got my car painted lol" i'll mess with it tommorow.. im loosen some ground when it gets that high of an rpm still in 1st.. i'll see tho thanks for the help guys.. i'll let yous kno how it goes tommorow.. heres a pic lol
Attached Thumbnails car is floored.. shifts at 6800 rpm in first not good-00_00005.jpg
Old Oct 19, 2004 | 06:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Car does look good
You might want to check the governer for damage or recalibrate it to shift sooner. The TV cable can cause high shift points but if your diving normal and shifts are good its not normaly the TV cable. BTW they (TV cable) auto adjust when you floor the car and the cable is too tight unless the end is damaged.
Old Oct 19, 2004 | 06:35 PM
Car: 2002 SS
Engine: Ls1
ok i should have said this in the begginging.. the car is totally fine when driving normal like a granmom shifts fine... then when i get cocky from a stop and put it to the floor thats when it shifts high as a mo fo
Old Oct 19, 2004 | 07:17 PM
First, check the level of the fluid in the tranny! Forgot to ask that... Once you have verified you have the proper fluid level, check out the thread from transflexio on how to adjust the TV or detent cable. I'm thinking your fluid level is high..or the cable is not adjusted correclty????
Old Oct 19, 2004 | 08:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
First, check the accuracy of your tach.
It's lying.
Old Oct 19, 2004 | 08:02 PM
Car: 2002 SS
Engine: Ls1
are you kidden me?!?! i can tell when to shift a motor,, she is whinning so much that the car is coasting before it even shifts.. all the power is lost its the shift accuracy thats off.. trust me
Old Oct 19, 2004 | 09:04 PM
EvilCartman's Avatar
Car: '82 Z28
So did you do a search on how to adjust the TV cable yet? There's lots of info and pictures.
Old Oct 19, 2004 | 09:38 PM
maybe you have a bad torque converter?? Do a search on that... I have never had a problem with mine, but i did recently change mine to a vigalinte3000. I wonder if it is bad? IF so, I have a stock one that is sitting in my garage. I think the stall is 2032 which is marked on the unit.
Old Oct 19, 2004 | 09:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's lying.
I always get a good kick out of that one but what’s this? No rant about how it’s an option not an instrument?
RB makes a good point like always! Factory tach's are not a real good indication of actual RPM. They do tend to be way off. I know that my tach is close until 4k or so then it starts to read low but its not uncommon for them to spike and read higher then normal.
I just cant see plugging one of those big honking 12k wet dream “tacometers” into the bird.
Tacometer-
Translation, 8in+ tachometer as seen in every Taco Bell employee’s import.
specialized
Jun 18, 2022 09:26 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
Sherpajames
Aug 7, 2015 06:56 PM
