one simple question about setting the timing...
on an automatic what rpms does the car need to be running to set the timing?
86 tpi
[This message has been edited by Z-BOSS (edited May 23, 2001).]
86 tpi
Idle, so.. around 1000 rpm's in neutral.
Also note the RPM will change when you adjust the timing.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
Car: 89 IrocZ
Engine: L98-ish
If alls working well, and resonably in spec, you should idle about 750rpms on a stock motor.
If not, you should look through Tech Central and adjust min-idle speed.
1000 rpms in nuetral/park is too high.
Car: 82 camaro SC
With a good tranny, 1000 rpm in park will bark the tires when you put it in gear if you have a stock TC.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by Enkil:
That 750 target RPM was in drive, I thought.</font>
The EFI cars are better at controlling idle than the older carbed (pre-ECM'ed one's) are.
