Has anyone put a surpentine pulleys on a 400
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
will the reverse cooling work on a 400 sbc. I just bought the pullies and brackets to change it over. Will it affect the cooling or make it overheat.
www.geocities.com/camaro1j/myz28.html
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
spohn torque arm and crossmember
t-56 trans, [wier racing bellhousing and hydrolic throwout bearing]
9" ME rearend 3.91 Gears
406
accel supper ram
afr heads
Car: 92 Camaro
Engine: 406 sbc
I have a crane cam it has alot of power.
part# 119831
grind # hr-284-2s-12 IG
222.0-230.0 duration
509-528 lift
2500-6000 RPM
LOOK AT MY WEB SITE FOR THE REST OF MY MODS.
406
accel supper ram
afr heads
part# 119831
509-528 lift
2500-6000 RPM
406
accel supper ram
afr heads
ambainb
04-25-2016 09:21 PM
Navy8125
08-22-2015 07:13 PM
db057
08-11-2015 10:11 PM
