how to get 400HP out of a chevy 355
Old Nov 2, 2004 | 09:16 PM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I have a newly rebuilt chevy 355 with a fresh set of 882 heads with 1.94 intake valvesand want to know what I could do to get as close as possible to 400HP with out hurting its streetability? It is going into my everyday driver and if at all possible I would rather not have a stall. I have a 700r4 with a shift kit going behind it.
Old Nov 2, 2004 | 09:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
What pistons do you have? Because with those 76cc 882 heads your compression is gonna be in the 8's. Not good, to get where you want i may be a good idea to get a worked over set of 305 heads or some Protopline 906 heads. But those 906 heads will require a specific vortec intake.
If you don't want a stall you are pretty much limited to getting way better heads.
Old Nov 2, 2004 | 09:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree with ME Leigh (check your other thread just below this one, about the exact same thing).
Old Nov 2, 2004 | 09:33 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Thats what i said in your other post Mike.
Old Nov 2, 2004 | 09:48 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
At least we're on the same page, Leigh.
Old Nov 2, 2004 | 10:02 PM
I have an H.O. 305 in my car now, would thoose heads be better?
Old Nov 2, 2004 | 10:08 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Much. Look up a guy named Sitting Bull. He has some great directions in his signiture for porting and polishing 305 heads.
Old Nov 2, 2004 | 10:29 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The 305 heads would be a much better starting point than 882's for a 400bHP motor.
Trash the 882's the 305 heads will need Full On PORTING and Larger valves (1.94" x 1.60")
The small chamber will go a long way in getting the compression up where it should be. (10:1)
Check the head casting numbers before you start.
416's or 081's are best.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
codeysabatini
Nov 10, 2015 04:07 PM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
darwinprice
17
Oct 11, 2015 11:51 PM
