Need to stop leak, what should I use please help?
Old May 28, 2001 | 10:24 PM
vadrad's Avatar
Guys I have a small engine leak and as far as I understand its from the rear engine seal since I dont want to pay lots to get the seal changed I am asking what is the best solution, addative to the engine oil to stop this leak.
Old May 28, 2001 | 10:37 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
replacing the seal is very easy and the only way to stop the leak. Just drop the trans, yank out the old seal and slap the new one in.
Old May 28, 2001 | 10:45 PM
vadrad's Avatar
Sounds simple but I have no crane for the tanny nothing how can I just take it out. I have basic tools.
Old May 28, 2001 | 11:02 PM
Enkil's Avatar
Crane? Weee don't need no steeenkin' cranes!
Anyways, the transmission is basically just bolted on. Basic tools will get one off. To support it, the ground works. Of if you want, put some wood blocks under it, or an old book.
I suggest you put a jack under it and snug the jack down securly on the tranny, almost to the point of lifting the tranny off it's mounts some. That way when you get the final bolts off you won't drop a tranny on your head. Don't like seeing thirdgenners in the Darwin Awards.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85 Jimmy
Sep 30, 2015 07:56 AM
84redta
Sep 19, 2015 09:58 AM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
