High Idle after hitting wall.
Old Nov 4, 2004 | 10:09 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Well, I hit a nice size puddle of standing water on the highway during some rain and slid into a concrete median wall in my Z. The car died when I hit the wall. I got it started, but the idle is high, around 1600 rpms. It's a smooth idle, not rough. Everytime I start the car, it idles normal for the first 15-30 seconds, then it jumps to about 15-1600 and stays there. Does anyone have any idea where I should start looking? IAC maybe? Thanks for any input.
Old Nov 4, 2004 | 10:56 PM
sellmanb's Avatar
Car: '86 Berlinetta
when you hit the wall i'm going to make an assumption that you didnt brake anything, just scraped a quarter panel or something, not a radiator buster or anything.
I bet if anything you knocked a vacuum line out off somewhere, or the impact was enough to make a brittle vacuum line break out somewhere.
Any other description you can give if it's not a vacuum line?
Old Nov 4, 2004 | 11:49 PM
RSpeed's Avatar
Wasn't just a scrape on the quarter panel
I thought about the vacuum lines, I just haven't had any time to really get into it yet. Spent my last days off work straightening out the face. I'll have to wait till I get another day off work to troubleshoot the idle. And there's really no other description or symptoms other than what I described at first. Just trying to get some thoughts on the matter so I can have an idea where to start once I get into it. Thanks for the input.
Old Nov 5, 2004 | 12:07 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It kinda sounds like your engine computer is not going into closed loop and is staying in open loop. Hows your gas mileage? Does it show any codes?
Old Nov 5, 2004 | 12:10 AM
sellmanb's Avatar
Car: '86 Berlinetta
RSpeed that made me cringe, looks like a beautiful car... please never hurt that car again! LOL
Old Nov 5, 2004 | 03:41 AM
RSpeed's Avatar
Gas mileage is bad. Can't get it to throw me any codes. There's a way I can put it in closed loop, isn't there?
Old Nov 5, 2004 | 07:29 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Replied over here:
https://www.thirdgen.org/techbb2/sho...10#post2067610
evilstuie
Jan 9, 2020 08:29 PM
db057
Sep 4, 2015 07:57 AM
Dialed_In
Aug 20, 2015 01:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
